I installed my 5.3 motor for fitting the other day on my 66 and when all is said and done the oil pan is barely resting on the rack. I am running a heidts front end with manual rack. F-body oil pan. Dirty dingo adjustable motor mounts. Short and wide type energy suspension motor mounts.
I just need about 1/4" to get the pan off of the rack. Im debating how to go about doing that. My idea is to make spacer plates to go between the dirty dingo and the energy suspension mounts and get slightly longer bolts. Has anybody else run into this problem? If so how did you fix it? and if there are any suggestions out there for better ideas im open to them. I dont really want to have to cut on my front end, since it is painted already. Thanks!
