Clutch pedal
4K views 12 replies 8 participants last post by  chevynuts88
#1 ·
Does this look right? I just installed this clutch peddle and it seems too low.
Is the clutch peddle suppose to be this low??
This is a side view. It only has a short travel distance.
This is the stop that is keeping it from returning higher.
Does anyone have any pics of their installed clutch peddles on a 67?
#2 ·
its wrong,not gonna work like that,the clutch pedal should be parallel to the brake.have you got an assembly manual? the best 20$ youll ever spend,it will show you in diagrams how to assemble a nova everything almost for some things like windows you need a chassis manual,another wise investment if your gonna be doing a lot of wrenching on yer ride,good luck
#4 ·
I may be wrong, but you may have some earlier peddles than a 66 or 67. If my memory serves me correct you can use these you just need to cut the bracket off and reweld the stop in the correct location.
#5 ·
That's weird. I just did the same thing in my 69 and I don't have that stop. Mine is parallel with the brake pedal. I used the automatic "bracket" as well. Possibly a variation or something they removed going to the 3rd gens? :confused:
Matt
#13 ·
He is missing the rubber stop. That would make the pedal even lower! He must have the wrong pedal. Shortening the pedal is the only other choice . Make sure you get the rubber before figuring out how long to make it [or it will clunk]
#12 · (Edited)
I used a 94 camaro donor and adapted to nova mount. I did away with park brake handle and put in Honda foot operated.You can use different brand and type slave-Mcledo has a hyd throw out brg and there are some made to mount to bellhousing-both are good.
