Hello, to take a long story short: does it make sense to create a vacuum in the crank case?
Here`s hat we need to get out of the crank case:
- overpressure inside the crank case
- gases and condensed water
For that case I put a PCV in one valve cover and a breather into the other.
The problem:
- hot gases and oil crap is going down the carb instead of fresh air
- the vacuum that pulls the air/fuel mix down the carb is not as strong as it could be
- the break booster and PCV is connected with an "T piece" and end in the carb. I know, that is a no-go but I do have it set up that way and the problem of course is, the break booster is not 100% properly activated that way.
And here`s my question again in detail: Can I throw the oil breather out and just simply put a plug in there so the PCV is creating a vacuum inside the crank case? That way the break bosster would work fine, the overpressure is gone, and the gas and crap are still pulled out.. just not in such a high flow anymore. Means the carb is getting better mixture of fresh air.
I saw set ups where no PCV was installed at all, just two oil breathes, however they were full of oil that was drippign out of them. Also what I saw was a connection on both sides down to the header collectors to create a vacuum that way.
So again, does it hurt the engine in some way long or short termed if I create an PCV vacuum inside the crank case?
Here`s what it looks with the PCV and plug in place:
The problem:
