I thought I explained that. Because the pinion and transmission tail shaft are rarely on the same plane it's kind of hard to tell how much U joint angle there will be without the drive shaft in place. I never said the drive shaft should pointed straight into the pinion and tranny. It should be
CLOSE but but not straight on.
ALLT4 said:
it's easier with the drive shaft installed to see how close it is to being pointed straight into the pinion and the tail shaft yoke.
Does that say anywhere it should be straight on?
IMHO the pinion should always be pointed down in relation to the drive shaft, when the torque hits it brings the drive shaft closer to straight on. If the pinion is pointed up in relation to the drive shaft the U joint angles can only get worse with torque applied no matter whether the tail shaft is up or down.
Probably doesn't make a hill of beans difference in a 4 link but on a leaf spring car it's way important to have the drive shaft pointed up to the tranny instead of down to it. Like I said, you're either going to see it in your mind or your not.
U joints are suppose to have some angle to them but not excessive. If you don't want to pay any attention to those angles so be it. But to suggest they aren't important is misleading.
That's the part of the article I'm talking about that they don't make real clear.
