I'm about to install a new blower motor in my '74. The car has been apart for years, and I had a custom shop do all the wiring for me. I ran out of money when they were about 90% done with the electrical. One of the things left undone was the fan blower motor.
Anyway, I'm looking for how to electrically connect the motor. I can see it takes a single spade connector, and I've read that should go to a relay under the hood. I *think* I've located the correct relay (second picture below), but need verification. If it's the correct relay, I don't know where the wire is that goes to the fan. All of the wires off the back of the relay disappear into wire covering. If I had to guess, I suppose the solo wire (as opposed to the triplets) coming off the back is the one I'm interested in. Can anyone verify that?
Assuming I've identified the correct wire, I guess that means I'll have to pull apart the wiring cover and see where the end of that wire is. Then I'll have to free it up from all the other wires and route it back to the fan motor. Correct? If so, what is the proper routing?
The only two electrical devices I've found anywhere near the fan motor are mounted on the A/C suitcase (pictures below). Assuming the second picture is the blower motor relay, anyone know what the other device is?
And, one last thing. Does it make sense to sand and paint that ugly relay (assuming that's what it is), or should I just order a new one since the one that's there is probably the factory original?
