Timing will also have an effect on the ground strap, moving the discoloration and changing the colors, so timing should be played with before jumping to changing the plug heat range. I argue that if it's a mild, mainly street-driven car, the 45 heat range would probably be better at frying deposits. Then again, I guess the OP might know what heat range the engine likes.
