I'm looking to replace my stock mono leafs. But I'm stuck trying to decide what to go with. One piece mono, Split mono, Multi or Coil Overs.
I know there's a TON of threads on here discussing different issues on this subject. But none that cover them all together, at least that I've read. :turn: . So sorry if this is a repeat.
I'm one of those guys that's all over the board when it comes to what I use my car for. I'd like something that rides nice for cruising, handles good, and is good on launches. Of course you can't get all this in one spring that I'm aware of? Each has their specific purpose. If I had to rate them I'd say cruising and cornering are tied in first and then 1/4 mile drag racing comes in third.
How stiff are the Hotchkis TVS multi leaf springs? Are they too stiff to give good weight transfer to the back on launches?
How's cal-trac's? This setup is mostly for drag racing correct?
How's CA g-bar setup? Best for?
Cut and past the below with your responses if you would. Thanks!!
Pro's
Mono:
Split Mono:
Multi:
Coil Over:
Cal-Trac's:
CA G-Bar:
Con's
Mono:
Split Mono:
Multi:
Coil Over:
Cal-Trac's:
CA G-Bar:
Pro's
Mono:
Split Mono:
Multi:
Coil Over:
Cal-Trac's:
CA G-Bar:
Con's
Mono:
Split Mono:
Multi:
Coil Over:
Cal-Trac's:
CA G-Bar:
