How tall of a rear tire on a 67 Chevy II?
4K views 12 replies 6 participants last post by  64PRONOVA
#1 ·
So, I see all sorts of threads inquiring as to how "wide" of a tire one can put on their Chevy II Nova. I figured I'd change it up a little... What is the tallest tire (in inches) that will fit (without rubbing) in a stock wheel well (without mods) on a 67 Nova? I'm thinking (hoping) this answer does NOT have to go down the route of wheel widths, diameters, and back spacing since I just want to know what "heights" folks are running.
Here is the scenario: At 70MPH, I'm sitting about 3200RPM in top gear going down the highway. I am wanting to drop my RPMs (some) and also increase my wheel size to a Rallye that is 17" or larger to tuck more wheel in the those gorgeous Tuxedo Black fender wells. I'm running the TCI 4-bar so, I don't have any issues with front to back or left to right tolerances. Currently, I have a 15 x 7 (4.25BS) rallye wheel and a 235 x 60 x 15 (26.1" tall) on my Deuce. I have a 3.55 gearset in the diff. No, I will NOT swap out my Muncie Rock Crusher or drop gear down to 3.08 to drop RPMs... I want lower RPMs AND more tuck! I think I can get both! :p
Reply with a tire size and we'll take it from there!
#2 ·
#4 · (Edited)
the problem with using tire to drop rpm is it doesn't make much of a difference as you see with only 300rpm drop with 28" tires
then there is what is meant by fit, this is a personal thing
even 28" are not going to fit if you want car close to level and a decent ride height with anywhere close to stock wheel wells
plus you would have a hard time getting 28" tall without being too wide
look around this site for pictures, most of the cars that have the max width for the wheel well are using somewhere between 45 series 17" to 35 series 18" to get the width they need and keep the tire from getting too tall
there may be someone on here that knows of the perfect tire wheel combo that would get what you want
but in my experience, I don't think you can get both
plus you have told us nothing about your engine, that can really effect what is a good cruising rpm
edit: I just looked at tire rack, BFG does have 225 to 255 in 70 series 15", these are 27" to 28" tall
but with any of these getting the ass end sitting down at all may be the issue
#5 ·
Great points! I have coil overs and a 4 bar set up out back so getting the rear level is much easier for me as I can drop spring heights (or swap coilovers if springs wont do it). I'm trying to only get tallest tire in a stock fender well so that's why I left motor info out (I guess I could have left out the trans and gear info as well as that doesn't help me get a tire height). Tracking on Tire Rack with 28" tall tires for 17 and 18" wheels. Hoping someone is running 28 or taller... Thanks for the post! :)
#6 ·
but you are asking questions that no one can answer for you, that is what I meant by stating fit is a personal thing
you will be able to fit 28" tire with the rear high in the air
you will not be able to get the below look with 28" tires, without going pretty narrow tires
these tires are about 25", you will be 1-1/2" higher just from axle height
#9 ·
I feel like "fit" is mechanical and look is "personal". Your comment about the axle tube being higher with a taller tire helped me determine that I need to measure the distance from the top of the tire to the top of the fender well and then subtract out the 4" of travel I use with my coilover suspension. Thanks! I think I'm on it now!
#7 ·
here are some more examples
first pic is how I bought the car, rear is high as wheels are too wide, but it would need to be high to fit 28" tires inside wheel well
second pic is after fixing the abomination and has 24.7" tires
#8 ·
I am building a 67 right now and I believe the tallest you can go is 26“ without jacking the back way up like was noted above. The place you need to look is the wheel opening front to rear. That distance is limited. So I run 26” as I have my rear lowered. And btw my rears are mini tubbed.
Rob
#10 ·
This is a 275/60 17 which is 28” tall. It’s not so much the height, it’s the front to back in the well. These are just rollers on a narrow jeep wheel with spacers, but it is practically touching the front of the lip. I’d say a 27” tall would be safest not knowing all the details of your rear setup.
