I can tell you how I did mine.
I got a big bearing 9" housing at a local swap meet for 60$ The housing was already stripped of all its brackets and stuff.
I sent the housing out to a local company called DutchmanAxles.They narrowed it,built NHRA legal alloy axles,installed a drain plug,gave me new seals,6" wheel studs,retaining brackets and bearing for 565$
I got a complete used 11" drum brake assembley of of E-bay for 39.00$
I had to drill the drums to a Chevy bolt pattern my self.(Dutchman asked which bolt pattern I wanted,I told them Chevy, I should have said Ford...Oh,well)
I bought a CAW case,with a full Moser aluminum spool,4:11's almost new and already set up. From a nice gentleman on this site for 200$.
So in just the rearend,not forgeting brakelines,bolts,nuts,breather valve etc,I'm in it about 900.00$
Not to bad.
Brandon
