Can someone explain how to get the distributor on a 194 6 cyl installed correctly oriented/indexed? Maybe there is some online resource with videos? I have checked, double-checked and triple checked TDC on cylnder #1, so I think I am good there. I marked TDC on the harmonic balancer and aligned that mark with the zero degrees advance on the tab on the timing cover. Then, if the distributor was a clock face with the engine side as 12 o'clock, forward side 3 o'clock, etc., my #1 plug wire is at 3 o'clock when the rotor points to 4:30!?! What is wrong with this picture? Any ideas?
Mikie
Mikie
