OK, I've never heard of this happening before, but someone else may have, so I'll explain it in the best way I can.
When I floor(Full Throttle) my car (70 Nova) in first gear, it accelerates and runs great until about 4200 rpms and then it starts popping and sputtering, until I shift it to 2nd, and it runs fine until 4200 rpms and does it again, shift to 3rd, it runs good.
Today, I took it to the (cough) street, and gave it 3/4 throttle in first gear, and I was able to bring it up to 5000 rpms, which is my usual shift point, and it ran perfect. But when I floored it, it still sputtered and popped.
It almost sounds like an extremely bad vaccuum leak, but it only does it a high rpms.
The only thing I can think of is my carb spacer, which is a 4 hole plastic coated phenolic. I don't know if it could be warping at the higher rpms or what. That's the only thing I changed before it started doing it. I had an aluminum open spacer on there before. The thing is, even shifting lower than usual, the car still went faster.
Would an aluminum 4 hole work better possibly?
If anyone can give any insight on this, it would be much appreciated. thanks in advance.
