1 - 1 of 1 Posts
ok here we go again....im doing an lt1 swap and want to mount a muncie 4 speed behind it..my lt1 block is drilled and tapped for a mechanical linkage so im pretty sure that it will work and i know that the Lt uses the same bellhousing bolt pattern as the 4 speed. My question is about the flywheel/pilot bushing? how can i make this work with an orginal lt1 starter? and where can you buy a flywheel that will work ?
1 - 1 of 1 Posts
