It reads a constant full.
I don't think it's grounding problem. My battery is in the trunk and I took the sending wire and grounded it right to the neg terminal. No change.
I unhooked the sending unit wire, and it goes to empty.
I checked continuity at sending unit wire and a ground, continuity is zero.
So, went out and bought a $20 gauge, hooked it up to the sending unit, my battery negative and the battery positive, turned the key and it runs to full.
Before I drop the tank, can I be safe to conclude it's the unit itself?
Am I missing anything?
My 68 had a gas gauge problem too, always reading full. So I grounded the wire leading from the gas tank (located in the trunk by latch) and this caused the gauge to drop to empty tank so I knew the gauge was working so next we replaced the fuel tank sending unit and it fixed it. I guess the stock sending unit finally gave out and read a constant open circuit (no resistance).
65 Super Sport
When I worked for GM years ago the range was 0 - 90 ohms. If there was an open circuit, "wire disconnected at sender" the fuel gage read over full.
I found this info that should help:
http://www.tanksinc.com/index.cfm/page/ptype=results/category_id=159/mode=cat/cat159.htm
Finally got a chance to get back to the always full gauge, and discovered the gauge was a 240-33 ohm, which didn't match the sending unit.
All good now.
Thanks everyone.
