After much debate on what I was going to run for a motor...I finally made a decision. I am officially part of the LS group. I ended up going with one of the L92's that Frank at www.gpsuperstore.com had. For those of you that don't know what the L92 is, here's what Pace Performance has about it:
Standard equipment on the 2008 Cadillac Escalade and GMC Yukon Denali, the L92 has brought Corvette technology into the truck market. The L92 engine brings you the same 403HP @5700 RPM effort from a 6.2L Vortec V-8 small block that borrows from all of the features that have made our LS family of engines world renowned for thier efficiency, design and performance. Now the L92 is available to you as a crate engine from GM Performance Parts. The 6.2L L92 engine features an all aluminum design: deep skirt 6 bolt main LS block, variarble valve timing, coil on plug design, high-flow L92 heads designed with influences from the LS7 Corvette head, true 4-into-1 exhaust manifolds, hig volume intake plenum, beehive valve springs, cast aluminum rockers on needle bearings, and a large volume throttle body.
Here's also a good thread about it on www.ls1tech.com http://www.ls1tech.com/forums/generation-iv-internal-engine/499059-ls3-l92-info.html
This engine is 403hp and 417tq stock. The displacement is 378cu in. It is basically a truck version of the LS3. If I was to take out the VVT cam and put in a LS3 cam, they would be almost the same (from what I understand).
Here are my plans for the motor:
- Get rid of the truck intake and put on a car intake, either the corvette one or the new FAST 102mm intake
- Cam, springs, water pump and 3 bolt timing gear upgrade. Will likely go with a comp cam: 231 / 239 at .050, and 616 / 623 lift
- Vintage Air Frontrunner or Billet Specialties serpentine kit
- I plan on keeping the VVT technology. Right now Mast Motorsports is the only one that is producing an aftermarket computer to run this set up. I will likely go this route unless by the time I need it, there are more on the market
- Speed Tech/Stainless Works polished stainless long tube headers http://www.speedtech-performance.co...egory_id=230/home_id=230/mode=prod/prd183.htm
- Autokraft oil pan and motor mounts
- polished valve covers with some type of coil relocation set up
With the cam upgrade, I've been told I should be at around 525hp. I'm hoping with the intake and headers upgrade, I will be closer to 550hp when I'm all done.
Anyways, enough yapping and onto the pics:
I already bought the Autokraft oil pan and motor mounts. For some reason though the motor mounts were in the package. Need to make a phone call this morning. Amazing work though on this oil pan.
