Hello all, I mounted my battery in the trunk and now trying to get my head wrapped around how the wiring should go.
I don’t have enough posts to add pics, so bear with me as I try to write this out.
I have Powermaster mini starter.
So looking at the front of my Ford Solenoid.
I will call the large left terminal on the “S” side terminal “A".
I will call the large right terminal on the "I" side, terminal "B".
Is that about right?....be nice.
- So the positive battery cable goes to solenoid terminal A.
- Also attached to solenoid terminal A is cable that runs to battery at starter (+).
- On the right side solenoid B terminal is wire ran to ignition at the starter.
- From the “S” terminal on the solenoid I can wire that to the previous wire that ran to the ignition on the starter.
- I can run a power supply for the fuse block to the previous wire that connected the horn relay, key ignition etc
- No jumper between the battery and ignition at starter.
