Where can I get original style wiper blade refills for a 68? I tried Harmons and J&W but no luck .I went to NAPA and they had something similar which was a universal kit that you cut to fit,but compared to the original one I have it was garbage.:confused:
Checked on line and found a part # for the wiper blade assembly at Napa ( WIP601647 ) and Advanced Auto ( 33-162 ). Your local Napa store should be able to order the assembly for you. I purchased the wiper arm & blade kit from Ground Up and it is not correct, it has 15" blades not the 16" like the factory. I couldn't find just a refill, you will probably have to replace the assembly.
Hope this helps.
Try:
www.nationalpartsdepot.com:)
They have 67-69 15" Anco & Trico refill sets & wiper blade Assy. (satin, stainless or black assy.) $6.95-$7.40 refill, $8.95-$10.95-$16.95 assy.
Also have 70-76 16" Anco & Trico refill sets & wiper blade Assy. (satin or black assy.)$6.95-$7.40 refill, $7.95 black-$11.20 satin assy.
I use 15" Tricos on my 69 Camaro.:yes:
But I am thinking of switching to the Trico 1970 16" satin assy. - $11.20
Gary
Discussion Starter · #5 ·
Thanks alot guys ,I will check out the places that you have mentioned
Thanks again Cheers :beer1::beer1:
