anyone know how the complete wiper arm with blade come off on a 95 S 10 pick up? i cant get it off. i need to remove the cowl vent panel so they have to come off... can anyone help? thanks
Thats exactly how my 97 wiper arms came off, remove nut and start wiggling. Mine were press on pretty tight so it took a lot of wigglying:
the wiper arm not me:rolleyes!!!!
67 4 door, 65 wagon (in pieces)
On my 91 S-10 there's a tab on the underside of the wiper arm that has to be pushed before it slips off the splined shaft. If I remember rightly, I had to take some of the pressure off the wiper arm to get mine off and it was pretty tough.
have u tried to remove the nut and rock the arm back and forth? thats how they usually come off.
no, i didn't see any nut. where is this nut located? can you tell me where this nut is please? also i noticed some plastic on the arm at the base of it, is it under there? if so how does this plastic come off? thanks so much
Plastic is just a cover and is pressed on over the lower arm- it lifts off and snaps back on.
Nut that holds the wiper blade on is underneath that.
Discussion Starter #7 (Edited)
hi thanks. i tried to get this plastic cover off to access the nut underneath it but no luck getting this plastic cover off the arm. is there a special way it comes off? or what side should be pulled on? or in what direction? i didnt want to pull to hard today because i was afriad i was going to crack the plastic... please help,
thanks
Plastic Should pull up from the base of the arm, might have to coax- or pry slightly with a screwdriver (watch not to chip plastic) - This should not give that tough a time.
Then undo nut and pull or pry wiper arm.
