Are the 68-74 windshields all the same as far as size goes? my 68's front windshield is cracked and separating, but i have a 74 4 door that has a good windshield that I could pull out if it will fit.
Thanks, Tyler
The windows are different between the 2 door and the four door. If you can find another 2 door 68-74 they are interchangeble.
4 doors are an inch taller, I'm assuming it was to make them more user friendly, then sporty!:yes:
the doors on the 4 door are also way shorter! (ruined my thought on putting in the pass side window that didn't come with the 68)
so I think i read somewhere that the 68 doors are different than the other years, is this true? if so what about the windows? and where can I get a pass side window?
The mechanism for the lock and window crank are in different locations. They can be modified or altered to fit 69-up, think the windows interchange, but I'm not 100% sure.
