1 - 9 of 9 Posts
Hi guys,
I just got a '71 nova 2D, in looking it over the felt/weatherstrip that's in the window channel is really bad. Which of the available re-pops are the best and who has them? I'd like to replace both front doors and the rear windows also, i have new outer "fuzzies" that go along the top edge of the door (bottom outside of the window) and the rears too.
Don
Looked at parts123, the channel weatherstrip looks to be just a roll of the stuff, not molded like the door-frame for the corners..etc. :-(
Guess i'll keep looking, any other reccomendations?
Don
1974 Nova, 1977 Nova
Don
From what I've seen & purchased, they're all like that regardless of where you buy it.
And the originals I've seen weren't molded to fit in the corner either. They just had a V-shaped notch cut in them so they'd fit the corner. Just use your old ones as a guide to cut the notch in the new ones.
Ok, i didn't know that the channel corners wasn't molded. :) The PO had stripped the interior for painting, lots of stuff is just gone so i've got nothing to compare against. lol
Don
Try Lutty's.com they had the fuzzies for mine and you have an option of oversees or local products (a little bit more) but there well built and fit nicely
Discussion Starter #9
Ok i'll look at their fuzzies. The PO said he had a new set in the box, and new acc carpet also that i need to pickup.
Thnks
Don
1 - 9 of 9 Posts
