1 - 12 of 12 Posts
I just got the Nova back on the road after 20 yrs of sitting, and I need tires at this point. Been searching the forums for a definitive answer. Any help would be much appreciated! I'm wanting to get the Torque Thrust D series
1970 Nova 4 door
Will either of these front setups fit disc brakes when I do that swap?
15x6 3.75" backspace with 215/60/15
15x7 3.75" backspace with 215/60/15
Will either of these rear setups work?
15x7? with 3.75" backspace with a 235/60/15 tire (drum brakes for now)
15x8? with 3.75" backspace with a 235/60/15 tire (drum brakes for now)
here's a link from steves nova site. a lot to read thru but sure your answer is there to be found. the front will be different from drums to disks. an some disk set-ups may move your mounting out 1/2-5/8''. after disks installed on my 66 i had to change from 3 3/4'' BS to 4 3/8'' BS with a 205 70 tire.
1972 Nova
The 15x6 in front should work for sure, the 15x7 might rub with disc brakes. In the rear, that 15x8 isn't fitting unless your axle is narrowed. With a 235 tire the 15x7 should probably work, it looks like it's only sticking out about 1/8" farther than my setup, but you might have to trim the inner fender depending on how things fit and what springs you have.
For reference, I have 15x7 4.25BS wheels all around, with 235/60-15 on front and 255/60-15 on back. I haven't been on the road, but everything seems to clear.
For a disc brake swap that doesn't stick out (DIY project), take a look at these links:
Everything you posted will fit with the exception of the 15 x 8 with only 3.75" backspace....and 8" needs at least 4.375" backspace to fit, 4.5" is better yet.
I've got 15 x 8.5" with 4.875" backspace with a 275/60-15 M?T Radials and it just clears the outside edge. '72 with factory front disc/rear drum, stock width rear axle. Passenger side will just rub the sidewall against the outer lip on a hard corner or with 2-3 people in he back seat, just enough to scratch up the sidewall so i trimmed that inner lip a bit. Stock ride height.
Thanks for the responses. T
I made a mistake. The 15x8 are 4.5 backspacing, not 3.75
I also want to say that my Nova is on stock L6 suspension still and it's sagging pretty good. I do plan to rebuild it all.
Maybe I'll look into
15x6 front
15x7 rear
1972 Nova
15x8 4.5BS might get into your shock or mounting plate, but they should fit. I put my brother's 17x8 Torque Thrusts with 255/50-17 tires on and it fit, but was really close to the outer quarter panel lip and up inside. I have 5-leaf springs on back, so I probably sit much higher than a mono-leaf car would. With stiff springs it would probably be fine with just trimming the lip. 235/60-15 tires would probably help a lot.
Driver side rear fits perfect but the passenger side is tight. I'll have to trim the lip some
405582
405583
405584
Do you think maybe the passenger side was repaired? The lip looks way different..
My 64 had the passenger side quarter panel replaced in a prior life and not really well executed.. That side was tighter on the tire as well. I massaged it out a bit from inside the wheel house. You might also be able to loosenthe leaf spring mounts on the. axle and see if you can shift the axle over a little bit to make a lot more space..
Discussion Starter #11
Yeah, it had a repair on that quarter along time ago. This was my dad's old car that's seen quite alot
I may try the 15x7 in the rear with 225-60-15
1 - 12 of 12 Posts
