1 - 3 of 3 Posts
I am missing my column for my 70, but have a extra 85 Monte Carlo SS column , will this work?
Also the 85 SS steering box? Will it work in a Nova? I know my 67 Impala has one....
Thank you in advance for any information! Jeff
The G body 605 steering box and column you have are setup as a forward mount steering box on a G body or S10 2wd. Your 70 Nova setup has the steering box located in a rearward location.. You will have to see if this is going to work out for this application..
Not sure it will work in your car but if it does you will probably need the column as well as the box because in late 70's the diameter if the steering shaft changed...so a 70 column may not work with the 85 box.
1 - 3 of 3 Posts
