Will a stock intake/exhaust manifold from a 64 194 fit a 67 230 ? They look identical... I pulled my 64 194 motor and replaced it with a 66 230. I have a 67 with a 230 that has a broken exhaust flapper doohickey that helps warm up the engine ? It rattles and sounds like crap when its cold so plus the choke is broke so I thought I'd remove it and install the exhaust/intake from my 64 motor that has a working exhaust flapper and a working choke. I'm guessing remove and replace ?:confused: Any help is appreciated :cool:
I have never tried to exchange these parts, but I believe they are compatible.
Set them side by side for a visual check.
The "heat riser" is necessary when starting a cold engine.
Bolts right on.
The carb WILL BE LEAN!!!
Ok, removed both int/exh manifolds. They match up visually and the entire process took about an hour.
to my surprise I removed the int/exh from my 67 and apparently it was previously on another vehicle:eek: The intake runners are a little different but overall it looks like it will bolt on:cool:
I did need to exchange the carburetors after I installed the 194 manifold on the 230. The 194 carb bogged real bad, plus it leaked:( I installed the carb from the 230 manifold and it purred like a kitten:yes: Now the choke works and the annoying exhaust rattle is gone from the broken exhaust manifold.
my next project
Detailing my 64 engine compartment, not going for Concourse just cleaning up a mess before I reinstall the donor motor.
