1 - 9 of 9 Posts
i was wondering what is the widest tire and rim combo you can get onto the rear of the 1st gen novas with a mono leaf spring? and not ones that rub going around every corner or hitting every bump..
thanks in advance
jon
I was able to get a 225/ 40 on mine with an 8" wheel and no rubbing. Tried a 245 and it would not work. With the right backspace I might be able to make a 235 work.
i currently have an 8'' rally wheel with 4.5'' of backspacing and a 215 65 15, and this combo is no problem, i wanted to maybe go with a 7'' rally w/4'' of bs and go with a 235 60 15 mt drag radial....
You might need a little more backspacing to make that work Jon. Do you know Cam Lumen's son? He runs a wheel place on Route 66 that can make you different backspacing.
i don't know him, maybe we can go on a lunch date and you can show me where it is?
you don't think it will work on which rim? the 8'' or the 7''?
and p.s., don't you work? how can you have over 5000 post's..........WOW:eek:
I haven't worked in over a year. I just sit and harass people all day!
I think you need about 4.25-4.5" backspace to stay away from the lip.
my 64 I had a 15x7 ralley with a 215/65-15 with no problems. A 235/60 will fit but with a shallow centerline 15x7 with a 5.5 or more backspace. Maybe try a weld wheel 15x8 with a 5.5 back space.
I just put new wheels and tires on my 63 I have 15x7 wheels on the back with 4.5" backspace and I am running Bfg 245 60 15 tires with no rubbing at all but that is about the as big of a tire that will fit. Don
1 - 9 of 9 Posts
