1 - 10 of 10 Posts
my 63 nova has the front seat that looks like a bench but the top part splits and folds in......i thought true SS seats were bucket.and how does the full console go in if you have the seat that i have mentioned?
Bucket seats and console came standard in all 1963 Novas with the Super Sport option. There was no other front seat available and no other 63 Nova had a console. Is there a possibility your car isn't an SS? Look for a 'Z' or 'X' on the bottom line of the cowl tag.
Bob
Bob
it has a z,and it looks like the original rivets in the tag. when i bought this car it had alot of pieces missing like the console.may not be the original seat.what else can i look for to make sure its a true SS?
There will be extra brackets by the trans tunnel to bolt the buckets to that a bench seat car will not have. Steering column should not have a shifter on it because all SS cars were floor shift I believe.
In addition to the SS only items already mentioned, all 1963 SS cars had chrome fender/door peak trim that ran the length of the car on each side. They also has a full set of gauges instead of idiot lights.
Just for clarification, if a 1963 SS had the standard 3 speed manual, it was mounted on the column and there was no console between the bucket seats. The console was only included if the optional powerglide automatic was ordered.
Bob
as mentioned the 63 ss had the one inch wide strip down the center of the dash, full gages in the cluster. I also was under the impression that the PG was standard on ss cars also.
All 1963 Chevy IIs, including the SS, came standard with a 3 speed manual transmission with column mounted shifter. The only other transmission available was the powerglide, a $163.00 option. On the SS, it came with the console and floor mounted shifter. Most SS cars got the PG, but you still see a few with the 3 speed manual and no console.
Bob
1 - 10 of 10 Posts
