Go with the LQ9. Transferring the turbo over to either the 6.0L or the 5.3L is going to be equally as difficult/easy since both are esentially the same engine with the only major difference being the displacement. Externally they are the same. The LS3 is a different animal all together.
It's like saying should I go with a 350 or a 383..I eventually want to swap in a big block.
Go with the 6.0L...I think you will be happy with the power it will make.
edit: someone correct me if im wrong but i believe you can put ls3 heads on the 6.0L since it has a 4" bore, but not the 5.3.
