1 - 3 of 3 Posts
I'm getting ready to pull the subframe out of the car and just need to disconnect the fuel line. I know that it goes under the car on the subframe but where would I disconnect it under so I can pull the top portion out with the frame?
I am assuming that a '73 is the same as '75 and later, but there will be a short length of rubber hose that connects the subframe end of the hard line to the rear section of the hard line that is attached to the chassis. It is located just after the end of the subframe on the passenger side.
Dan
Dan
Found it, thanks!
1 - 3 of 3 Posts
