Need to find out where I can buy the thick double 00 welding cable for grounding from battery in trunk to block?
I highly doubt you will need 00 for any type of automotive performance that doesn't have an electrical system built to handle something like a rolling amphitheater.
If you're stuck on 00 though, I like to go with wire specifically made for mobile audio. It's usually multiple strands which make it more pliable as well as easier to crimp ends onto.
http://www1.shopping.com/-0+gauge+wire
00Cable is not necessary and way to much weight.
You can get 1/0 battery cables at most part stores with no problem.
Al
A tractor supply store will usually have a welding section and I have bought my cable there a couple of times. Orsheln's was the last place and a resonable price.
Find your local electrical contractor supply house (outlets, conduit, panel boxes, circuit breakers, etc). I have found they always beat the chain store prices by the foot. Welding supply houses do about the same for price, but generally don't carry a wide variety of colors, insulation types or connectors.
