Hi , I hanvt ran my car at the track yet but if I go and run faster than 12 seconds do I need a battery cut off switch , im not sure of the time limit on this subjust , can anyone help ....thanks
If you have a trunk mounted battery, an outside cutoff switch is mandatory. And it must be wired through the positive cable. Dave
You need a cut of switch if battery is in the trunk.It must be able to 1-keep car from starting and 2 able to shut the car off instantly when running-they will check this at the track for tech.
yep, and yes they actually check it.:eek:
So don't forget to run your alternator wire through the switch too, if you run an alternator.
