Hello everyone
I know there is a code for rally rims for different years of nova's
my question is will a 14x6 gm rally wheel fit on a 69 nova with disc brakes?
or does it have to be a certain one?
thanks Brian
i have a 66 with disc brakes. the discs are for early 70's chevelle. i run 14 x 6 rallys with a 4 3/8 BS. these rallys came off of a 69 camero with discs, but i still had to grind a small amount from the top of the caliper bracket. they fit great now an the code at the side of the valve stem is YW. hope this helped you out.
My 69 came with drum brakes and 6" rally wheels coded XG. I converted to front discs with a Right Stuff kit and they fit with that as well.
Hey Kingbri . ………………………..
at the top of this "section"- - - "Wheels & Tires" - - - - - 4th post down "Rally wheel rim codes : by , taz .
Some good reading there . . . . . ! (y)
Also, some VERy GOOD info can be found over at CRG (Camaro Research Group = a Camaro site = = but , each section has really good info .
a lot of very good GM build / assembly line / number & stamping info .. (a lot is same as 3rd gen Novas) .
Note : beside the title - - "Wheel and Wheel Covers" - - - you can 'click on "WHEEL" , and go to the 'rim codes' ( go down, from there) .
