1 - 11 of 11 Posts
I hope that I'm posting in the right place. This is my first post. I am mini-tubbing my 70 Nova SS. I have determined that I will need approximately 5 1/2" or 6 " backspace to get 15x8's with 10.5s in the hole.
My question is about manufacturers suppling that much backspace on a wheel without having to buy weld wheels like everyone else? I would like ol'skool styles like Crager SS wheels or AR torq thrus wheels. I have even considered rallye style but it needs to have the required backspace.
Has anyone got a suggestion for me?
There is a sale of billet specialties on summit you might want to check out
check out earlywheel.com. They have rally's and then you can get any bs you want.
and personally if you are minitubbing it why not go with a 10" wheel, because I can fit a 15x8 with 5.5" bs and a 28x12.5 et street in a stock wheel well with the shocks relocated.
I've had 10.5's on stock 15x7 rally's, as well as 15x8-1/2" Centerlines that have about 4-3/4" b.s before the mini-tub.
5 1/2 or 6" is too much and will put the tire against the spring.
A 15x8 with 5" b.s. is the most common size that works with just nudging the lower shock mount over a little. (I drilled an extra hole in my slapper bars to move the shock)
After the mini-tub, I'm looking at 15x10 with about 5.5" b.s., but it depends on the axle width.
Thanks everyone...I have not mini-tubbed yet. I have installed a big 10 rearend with 373:1 and posi unit. we were getting ready to minitub when I thought about wheels. The gas tank has been removed, mono springs and slappers installed. We moved the monos to the inside put about 3* of hook in the perches and straightened the drag shocks to a more upright position. We were taking rough measurements and came up with 5-1/2 to 6 inches of backspace required. I plan to mount 10-1/2 tires on 15x8 rims. So I thought that I may be able to get away without mini-tubbing.
You have more experience with these things. Am I wrong about the backspacing?
Rally Wheels and proper backspacing?
I thought I would ask a question somewhere along the same lines as this guy? I want to put the widest stock rallys on front and rear that will match in depth ex. (15x8) and have the same back spacing on a 68 nova can anyone tell me what will fit? Thanks!
1 - 11 of 11 Posts
