1 - 10 of 10 Posts
just bought a 64 hdtop trying to figure out what size wheel and tires will work without any modifications
When you go to the website mentioned above my car is the blue 64 SS with the rally wheels. Lowered about 2 inches all around. Drives real well with barely a tire rub with a full fuel load.
Tim
thanks for the info guys I still have to order my wheels, thinking about torq thrust II was told to use 15x7 with 4 1/2 back space on rear with a 235/60 15 tire on the front same wheel with a 205/60 /15 tire what do you think
I could't find the Torque Thrust in the BS I needed so I went with the Wheel Vintique chrome rallys. 15x7 w/ 4.5" BS and 235/60/15 is about the max in the rear without some work. Fronts were 15x6 w/ 3.5" BS and 195 /60/15's. Had to adjust the fender brace but they fit.
I think you should measure your car to see what space you have in each wheelwell and get a set of wheels made with the correct backspace to center the wheel/tire in the wheelwell. Also determine the max tire section width and look for tires that meet your situation. You should leave 3/4" to 1" on both sides of your tires for clearance.
1 - 10 of 10 Posts
