1 - 12 of 12 Posts
I am trying to get and idea of my compression ratio on my 355.
350 block .030 bored
Flat top Diamond forged pistons with 2 valve reliefs
6" rod and piston is .020 in the hole
Edelbrock rpm heads with 64cc
Felpro 1003 head gasket .041 thick
Let me know if any more info is needed and thanks in advance for any and all help!!
piston dome relief is a estimate
gasket bore is estimate.
but this should be very close.
Al
with out the calculator i would have said 10.5 so yah your righ there! its going to like that spray!!:yes: with my 355 i picked up from a 12.6 to a 11.20 on a 150 hit with a combo simular to yours! and that was getting into the unit in second gear!:devil:
12.6 to an 11.20?!?!?! Oh man I cant wait!!! :devil: I want to be around 12.50 than add a 150 wet........I just want to run 11.50s....
Discussion Starter · #6 ·
Hell yeah that would work for me!!! I am hoping to go 12.50 -12.20 on motor and then spray it to 11.50, a 150 shot may be too much!NOT!:devil:
Naw,my lazy ars has not made the rear firewall yet!:sleep:
AND EVEN TO LAZY TO ASK FOR HELP. LOL! MAN I KNOW ITS HOT OUT BUT GET YOUR BUTT IN GEAR! MIGHT AS WELL GET IT DONE NOW CAUSE AFTER YOU GO UNDER THE KNIFE YOU DEF. AINT GOING TO WANT TO.:no:
1 - 12 of 12 Posts
