1 - 16 of 16 Posts
I've got a 63 ss convt. I'm trying to find out what size engine has. the number stamped on the block is F0608LK. I can't find the app. code for the LK. I would like to know size and year of this engine if possible
thanks for the reply joe .but the engine is a straight 6 with a one barrel carb,and a 3 speed tranny .
194 CI maybe?
:edit:
i found this list of engines for the first gen...
153 in³ I4
194 in³ I6
283 in³ V8
327 in³ V8
and it looks like the only inline 6 was 194 ci. hope that helps.
Discussion Starter · #5 ·
I know its suppose to be a 194 but not sure it is .the reason I'm not sure is the dip stick location? a friend has a SS convert. his dip stick is by the coil in the front and mine is back by the starter.just not sure if it is the original engine.
Discussion Starter · #7 ·
no problem Joe I should have said it is A 6 cyl. Is there any web sites I can find this kind of information and would the #'s on the block and head help any ? I tried novaresource.com it says it should end with a H or HB to be a 194 :confused:
JM,I should have also read better.A first gen would not have a BB.My chilton Manual starts at 64,so I have no 63 Codes.Is the K easy to read?
Discussion Starter · #9 ·
Joe all the letters are stamped in pretty deep .I thought I miss read them at first but is definitely F0608LK
if it isnt a 194 ci , i don't think it is the original, however this doesnt help you to find out what it is, good luck though.
Any Chev 194-230-250 is a fairly easy swap with any other. If you can get the casting number off the block, often underneath the manifolds it will help narrow down what is in the car.
Discussion Starter · #12 ·
Ok I checked the block and did'nt find anything on that side (drivers).on the passengers side in the middle, by the motor mount is 3850817 0 with GM under it. back by the dip stick is C O N 2 F 54 :awkward: hope this helps
3850617 is a 62-78 230 or 250. If you pull a spark plug when at tdc and the piston is a flat top, it is likely a 230 and dished a 250.
If it has flat top pistons it also could be a 194. The letter F means that the engine was cast in the 6th month (June). then the day of the month, then the year. I have 194 engine with the following J27 6 so it is an October 27, 1966 production motor out of a 67 Nova. Also, important is that 250 motors weren't produced until 1966. Good luck identifying it.
Welcome to the site. Always a good idea to check the date on the first post in a thread. The question in this thread was posted 14 years ago and the last reply before yours was also in 2007.
Bob
1 - 16 of 16 Posts
