I lost 1 of the small screws that hold the wheel cylinder to the backing plate. Anyone know what the size is, or, can I take the other 1 off and not have the wheel cylinder pop out of place? '66. I need this info asap please!
You should be able to remove the other screw. If the brake line is still attached to the wheel cylinder it will hold it in place, also if the brake hardware on the opposite side is still attached it will do the same.
Mike
