Thanks everyone! I thought it was the 8.5. So is this a good rear end?? Should I replace it with a 12 bolt or 9 inch?I agree with all posts above... definitely a GM 8.5" rear.
Thanks!! I'm only going to be running about 500hp. Probably going to shorten the rear so I will need to change axles anyways at that point.The 8.5" is a good rear end... and with some aftermarket items (axles, carrier), it can be built into a very strong unit.
The diameter of the pinion in a 10 bolt 8.5" rear is the same as the pinion in a 12 bolt rear.
Up the spline count from 28 to at least 30 when you do axles and differential....I'm not sure if anything bigger like a 33 spline is available.Thanks!! I'm only going to be running about 500hp. Probably going to shorten the rear so I will need to change axles anyways at that point.
