I've taken alot into consideration and I thank everyone for their input and help. The reason that I've went with the Eddy heads are because I'm looking for no more than 400hp and it will be a simple cruiser. Here's my setup;
-GM Goodwrench short block (4 bolt mains)
-Edelbrock Cylinder Heads (64cc combustion chamber, 170cc intake runner, 65cc exhaust, 2.020 intake valve, 1.600 exhaust)
-Lunati Voodoo hydraulic flat tappet camshaft (227/233 duration at .50 lift, 268/276 advertised duration, 110 degree lobe seperation
-Summit 1.5 ratio roller rockers
-2500RPM Hughes stall converter
-Cloyes double roller timing chain/gear set
-Edelbrock RPM Air gap intake manifold
-Holley 750CFM carburetor with electric choke and vacuum secondaries
-Milodon oil pump
-Moroso 7qt oil pan
Any opinions? I'm hoping to hit 400hp with this combo.
-Milodon oil pump
-Moroso 7qt oil pan
