1 - 3 of 3 Posts
By the '63 Assembly Manual it's called an upper bearing and horn wire (page 128). I think you would call it a bearing first, and the brass part is detachable from the bearing, I believe. I think the brass part with the wire comes with a new switch, or at least it did with mine. Even an old, dried out switch ought to still have the bearing and the horn ring wire part.
The bearing comes with the turn signal switch assembly. Not sure if you can buy just the bearing/horn ring.
Rob
1 - 3 of 3 Posts
