1 - 14 of 14 Posts
Hey everyone,
Just wondering what you guys are taching at 60. I just picked up a 67 and noticed it revs pretty high (in my opinion) at 60. I'm taching around 2500 RPM's at 60. It's got a TH 350 Transmission and I'm pretty sure it has the stock 3:08 rear end pushed by 355.
Mike V
Mine didn't have a tach in it, but I kept it at 60 mph with the 4.10 gears and 275/60 tires. I assume it was around 32-3300.
Hey everyone,
Mike V
What size tires do you have? (Width, height ratio, wheel diameter) You're missing one final piece to the puzzle if you want to know what your gear ratio really is.
i'm at 2150 RPM at 70, not a sure number at 60 mph. an this is with 0.70 OD an a 3.55 an 26'' tire. but i'm bettin at around 1850 for 60 mph.
I don't know about 60, but I'm turning about 3000rpm at 65mph with a 3.73 year and a 255/60-15 tire. Its 3500 at 75mph. A 2500rpm cruise engine speed isn't bad. You can drive all day at 4000rpm if you can keep it from overheating.
Mike - 74 Nova Baltimore, MD
At 60 mph, I'm at about 2130 rpm... but I am using a 2004R with a .67 OD, plus a lock-up converter, and a 4.10 rear running 26" dia tires.
Below is a link to a very simple calculator for determining engine rpm at a given speed based on your drive train and rear tire diameter.
Note: The calculator does not compensate for torque converter slippage (automatic w/o lock-up convertor).
https://www.crawlpedia.com/rpm_gear_calculator.htm
I see just under 2,000 rpm with a TH400 (1:1 3rd gear), 2.56 rear end, and 26.5" tires.
I plan to go much lower with the rear end ratio. When I do, I won't be surprised to see 3,000+ rpm at 60 mph.
1 - 14 of 14 Posts
