Getting further into the build. The door hinges and engine mounts are welded to the car. The hinges need new pins but other than that they seem ok. The engine mounts have not pulled the motor yet. Is this going to be an issue?
Well if the engine stands are welded to the subframe and they did a descent job with motor sitting right might as well leave them.
For the hinges you can get new bushings & pins... oversized if holes are out of round. So welded hinges should not be a problem. I had to file the bushing holes out to make them bigger to accept bigger bushings. Worked fine.
The welded hinges are usually only a problem when it comes time to adjust the doors - its a brute force effort...
