I got my first dealership gig in 1978 and your car was at or near the height of emission controls for carbureted engines. What a nightmare that was. You have 1 EGR valve bolted to the intake manifold. The other one is a vacuum servo or something similar. There were so many systems integrated back then that I can’t recall what that one did but they were all vacuum/thermal/mechanical as your photo will attest. The computer landed in the car in 1981 but most of that stuff stayed anyway.
You should be able to find a copy of the emission vacuum hose routing and follow it to properly connect everything. That just means you will find out what doesn’t work. It didn’t work worth a crap when it was new under warranty so you should have some fun in front of you.
The fuel line looks like the factory routing. At some point, someone tried to take the line loose without holding the large filter nut on the carburetor while they turned the tube nut. The filter nut broke loose first and they twisted the fuel line.
Steve
Steve
