I have been helping my buddy get his 71 nova running.We installed a "rebuilt'400 small block.Rebuilt means everything in the lower end is fresh.The cam and lifters,Oil pump,crank,Bla bla bla.I did not assembled the lower end.Besides the cam and timing chain.So I don't know what the clearance's are.
Anyway I spent last night and today installing 3 inch exhaust.And we got it all lined out.Changed the oil to some 20w50 valvoline Vr-1.And let the motor warm up.
We took off down the road and he laid into it a little bit.(5000Rpms)And a biggo trail of blue smoke was right behind us.We came back home and pulled the valve cover on the passenger side and check the rockers.Found one of them to be loose.Adjusted it and refired.Seemed to help.But still smoking....
Do you guys think it's ring?Would a compression test tell us?
I didn't install new valve seals on the motor.Could that be the problem.At idle it smokes very little.But when you rev it up she does it pretty bad....
Any advice would be awesome.It felt pretty good.But I think my old truck has got it though!
