1 - 3 of 3 Posts
Is there any difference to the bolt pattern on a small block water pump mounting flange vs. a big block water pump mounting flange? I am asking as I found a big block short water pump pulley that is exactly the diameter I am looking for, but I have a small block with a short water pump (measured from the mounting area on the block to mounting flange on the pump and it's under 6"). Thanks!
If the bolts for the fan line up and the belt grooves line up. It should be groovy baby!:yes:
The pump will not interchange the best I remember. The pullies will work as long as they line up.
1 - 3 of 3 Posts
