1 - 12 of 12 Posts
Which water, and fuel pump would you guys recommend. I think im going to put a fuel cell in the trunk. Electric or mech fuel pump? I have a 350 stroked to 383. Thanks in advance
I just checked them out sounds really good but $220. Any others that are a bit cheaper?
edelbrock looks good, how do I know if i need a long, or short?
Cool I ll check jegs again, as for a fuel pump whats the benefits of electric over mechanical? Its going to see more street then strip
depends on what pulley kit u have now or gonna buy.... since u have more of a street car, just run a mechanical fuel pump, there's plenty out there that will feed ur motor. good luck....
LIL JOHN
Discussion Starter #9
I have the stock pulley set up and Ill research fuel pumps
Discussion Starter #12
A short waterpump has almost no clearance between the timing cover and the back of the pump. Maybe 1/4" or so. A long pump would probably be closer to 3/4"-1" of clearance.
Thanks Ill go with long waterpump.
1 - 12 of 12 Posts
