1 - 2 of 2 Posts
What filler is best used over welds? I have read a lot of info but am not sure what is best.
I will be sealing most of my welds on the back side but some of my welds will not be able to be sealed from the back side.
Also should I prime first or fill and then prime.
Thanks for your help!
EarlyIIs
you should always try to make your welds solid so there are no holes in them. That way you don't have to worry about moisture coming in from the back side. You can use either Duraglass or Allmetal. They are both water resistant fillers.
1 - 2 of 2 Posts
