1 - 2 of 2 Posts
I'm putting a flat tappet cam in a vortec roller block. Will I need to reuse the lock plate in front of the cam?
I believe the answer is no don't use it.
Now if you use the factory roller cam in an old school block then I believe you grind the ears of off the plate and use it for a spacer.
See if someone else will chime in with more knowledge.
1 - 2 of 2 Posts
