Have any of you guys ever installed a Vintage Air unit in your car? I have mine almost complete, but when I connect the main power and ground, the fan comes on. Even with the controls unplugged from the unit, it still comes on. I called Vintage and their phone loop is one of the worst in the world, if you need help. I emailed them and am waiting on a response, but thought I would ask here also. Their instructions are somewhat lacking, as far as wiring goes.
edit, I got a reply from Vintage quicker than expected. There is a ground wire that is supposed to be for grounding the compressor, which is obviously grounded through the mounting brackets. That extra ground has to go to the battery and then both grounds MUST be connected before the power is connected. If not, the unit goes into default and the fan comes on high speed automatically.
I'll try that tomorrow.
