1 - 9 of 9 Posts
1966 SS Artesian Turquois
Getting it on the road after some time in the body shop. Engine seems to be running well, but after bring the rpm's up to 1500 and over in neutral I have a serious vibration in the seat of my pants hardly any in the steering wheel. set the timing at 10btdc. 327 350 hp cam 194 heads Gm manifold 585 holley stock distributor.
Need more info. Do you have this vibration at 1500 in park? If the vibration is only when you are moving it may be in transmission or drivetrain. Bring the car up to 25 mph in a safe place and turn the motor off and see if you have any vibrations. What work did you recently have done to car ?
Discussion Starter · #9 ·
I might have found the problem. When I rebuilt the distributor instructions said to saturate and repack the oil well with an absorbent material.when I removed the cap there was oil all over the points and half way up the cap possible shorting the points out.
1 - 9 of 9 Posts
