hello. looking for vapor and fuel lines for a 73 two door. have numbers for Right Stuff vapor and fuel but don't see a way to purchase directly from Right Stuff. do they sell direct or if not, whom can i purchase them from? other comments on other possible sources/brands welcome. thanks...............
Just bought new fuel lines from SS396: They come in OEM material and SS. I opted for SS. I also got new clips.
1969-1973 Nova Main Fuel Line, 3/8 Inch, Stainless Steel line&search_results=40&conversion_insert=Y&conversion_product_id=21282&cartype=nova&year=1973
1969-1973 Nova Main Fuel Line, 3/8 Inch, Original Material line&search_results=40&conversion_insert=Y&conversion_product_id=21281&cartype=nova&year=1973
1969-1974 Nova Fuel Line Clip Kit 14 PC (3/8 No Return) line&search_results=40&conversion_insert=Y&conversion_product_id=22177&cartype=nova&year=1973
The clips are available seperatley. I think the bolts are wrong that came in the kit they are too small.
SO I ordered a bunch of these which look like what I removed:
1962-1979 Nova Brake Line Or Fuel Line Clip Bolt line&search_results=40&conversion_insert=Y&conversion_product_id=2659&cartype=nova&year=1973
You can also get the rubber hoses and hose clamps as a kit, You ned two for the fuel line.
Vapor lines, SS is also available
1973-1974 Nova Vapor Return Line Set, 5/16 Inch, Original Material line&search_results=2&conversion_insert=Y&conversion_product_id=21307&cartype=nova&year=1973
I think the 6 cylinders came with 5/16" fuel lines, not 100%, but appears to be what I am removing. V-8 came with 3/8".
again not sure.
I do not intend on replacing my vapor lines as they are not used in my setup. I think the existing line is a vent, so I will make sure it can function as such.
BTW the lines come in a nice big box so no worries ( well LESS worries) about damage.
again not sure.
SThole, you can call the right stuff directly @ 800-405-2000.
again not sure.
again not sure.
sthole, You can call the right stuff directly at 800-405-2000. Plus their fuel and vapor lines are now made in USA.
I agree: I am replacing my stock 5/16" ( car originally had a 250 engine) with new 3/8" SS as I have a 350 in it now
