I have used this tester for several years. Works great as far as making sure all your springs are close to the same seat. Easy to fine a broken spring from reading.
I use it every time I run the valves to check seat pressure is equal all way through.
Have ran valves after cruising the streets and get ready to take it to the track and find a weak spring while running the valves and save a problem at the track.
Good investment in my opinion.
