Thanks Paul,
Thats what I've thought... It would be risky running the flat tappet with those springs. Brodix says they are first for hyd roller, but could be used even with flat tappet cams.
Yes, I know these heads need more lift to perform their best. The 274 cam was kinda emergency solution 'till I got some cash and step up to a roller. Well, those heads werent cheap and I already had the Isky cam & lifters here on the shelf. Thats why I first intended to use it untill I could afford a roller cam.
Anyway, I've got most of the parts for my engine, including a bored and decked 4 bolt block. I guess I can wait some more time before I'll assemble the plant, sell the Isky and buy that roller instead.
Do you have any tips on a good hyd roller that would work nice with my combo? I guess Im looking for one with pressed on "iron" dist gear, I better pick a small base, even though I dont think the clearance issue will be that hard coz of my stroker clearanced rods, but anyway...
Any tips would be appreciated, when it comes to bumpsticks, there's a jungle out there! Note, this car is intended to be used on the streets
Combo:
Engine: Chevy 350 bored .030 and stroked to 383
Rotating assembly: (Internal balanced)
Crank: Scat 3.75 stroke crankshaft
Rods: Scat Premium 7/16 ARP bolts I-beam 6” bushed connecting rods
Pistons: SRP forged piston & pins (inverted dome -16cc) around 9.8-10.2 cr
Rings: Sealed power 1/16 1/16 3/16 moly piston rings
Bearings: Clevite P rod & main bearings
Heads: Brodix RR 200 Alu heads with 64cc CNCd combustion chambers & 1.550 springs.
130 seat pressure 360 open .600 max lift
Intake Manifold: Brodix dual plane intake
Carb: Holley 750 HP carb
Exhaust: 1 5/8 under chassi headers connected to 2 1/2 dual exhaust (sidepipes)
Transmission: TH350 transmission with B&M Holeshot 1900 converter
Gears: 3.55 posi
Vehicle: 1963 Chevy II/Nova 3200 pounds with driver
Note; If needed I will buy another converter with higher stall, maybe even go with bigger primaries headers.
Thanks for your help Paul
Matt
